Originally Posted by krazykaboom
How do you like your 4.88 gearing? Are you towing alot? What are you running on the interstate for RPMs?
I like 4.88 gears with 37" tires for how I use my truck. My toy hauler is approx 13,000 lbs and my destinations take me up steep grades and over mountain passes. Truck feels dialed...
I have a local commute (no freeway). When I am unloaded on the freeway, I hold 80 MPH at 2,600 RPM the entire trip. The 6.0 likes RPM.
You stated earlier that you do not tow much, if ever. But, you may get a boat? I recommend 4.56 gears with your 38" tire setup.
2004 F350, 6.0L TorqShift, SRW, CC, LB, Lariat, 4X4, Built Feb 2004
8" Lift, Fox Shox, 37x13.5x17 Toyo Open Country MT on Weld Evo Velociti XT, 4.88 Gears, MagnaFlow Exhaust, AMP Research PowerStep, Auto Meter Cobalt Gauges (EGT Boost Trans), ScanGaugeII, Firestone Air Bags/Compressor/Tank, BulletProofDiesel EGR Cooler, Valvoline lubricants, Final Charge Global ELC, DieselSite Coolant Filter
