Diesel Forum - TheDieselStop.com - View Single Post - NEWBIE with WMO/RMO report and QUESTION/NEED HELP
Old 08-12-2009, 09:27 PM   #2 (permalink)
94_turbo
the lift pump in the center of the valley--may not like pulling 100% wmo--esp as it gets colder out, idi's have the same problem-------and about the chev oil pump--when you go from gravity feed, to pressure--your going to get larger particles passing thru the filters, in spite of their micron rating--also,check your fuel filter, it may be getting dirty--
94_turbo is offline   Reply With Quote
