Diesel Forum - TheDieselStop.com - View Single Post - Peanut oil use as lubricant?
Old 08-13-2009, 05:51 PM   #4 (permalink)
FryerJim
FryerJim's Avatar
2% soybean oil in kerosene will raise it's lubricity to above the required specification for automotive fuel.
2% in diesel will absolutely ensure it is above the spec!
2% of 29 gallons is .58 gallons.
Throw 1/2 gallon in at each fill up and you should be fine. Just make sure there is no water in it!
-Jim
Early 1999 F350 6sp Manual, CC, Dually, Long bed, 2WD, 3.73 rear end.
Almost stock, PO dualed the exhaust out after the rear axel.
Purchased 3 April 2009 with 122,500 miles on it.
9 June 2009 has 127,000 miles on it.
Mods to come later...
FryerJim is offline   Reply With Quote
