Diesel Forum - TheDieselStop.com - View Single Post - Lack of towing power
Old 08-20-2009, 10:28 AM   #4 (permalink)
Smiley1
Smiley1's Avatar
Check and clean your EGR valve. This simple, free fix has solved MANY issues. Changing the fuel filters is a good idea. Have a dealer search for codes and make sure the fuel pressure is where it shouldd be. The dealer can also check the temp difference between your EGR cooler and Oil cooler to see if there is an issue. If you have these replaced make sure you add a coolant filter to keep this issue coming up again.
2004 F250 CC FX4 / 46g Transfer Flow / ARP Studs / Coolant Filter / CCV
2004 Surf Side 30' pull trailer
1999 Pontiac GTP modified
1968 Pontiac Firebird (restored)
Smiley1 is offline   Reply With Quote
