Diesel Forum - TheDieselStop.com - View Single Post - Lack of towing power
Old 08-23-2009, 08:43 AM   #11 (permalink)
Lazyl
Originally Posted by BRUMFIJW View Post
Hate to pee in your cherrios but mine had the exact same symptoms. After I changed out my fuel filters and it made no difference, I had the egr cooler & oil cooler replaced and it solved all my problems. I tow 14,000#'s + regularly and mine pulls great. I believe the reason was that the oil temperature & coolant temperatures were going up (thus the fan kicking in alot) and the truck PCM was depowering via fuel restriction to regulate the temperature better & thus losing your horsepower.
I can now pull my tt, cattle trailer or hay trailer as fast or hard as my diesel reserves allow.
My question for you: My 2004 has the same problems as mentioned on orignial post. This is all a pain for sure but what happens if you just put up with it and let the whinning continue? Is there damage that can happen? Mine seemed to start after three years old and the fuel changed. I lost power along with the whinning but when I used the cetene boost the whinning continued but the power hung in there. Per his question above, what was the cost to change out the systems? thanks
Lazyl is offline   Reply With Quote
