Diesel Forum - TheDieselStop.com - View Single Post - 2001 4r70w Hard Shift Blinking Od Light
Old 08-23-2009, 12:40 PM   #4 (permalink)
GrampyJim
Banned
Your codes are indicating that a lot more than just you torque converter is slipping... your P0783 is even indicating some sort of 3-4 error.... I am going to hang my hat on some kind of slipping friction element... You might be able to isolate the concern by using a decent scan tool and watching two PIDs... GEAR_RAT (the PCM/TCM knows the ratios built into the trans and will display the gear ratio for the commanded gear) and TRAN_RAT (the TCM can compute the real time gear ratio through the transmission taking into account any slipping friction elements). TRAN_RAT and GEAR_RAT should be lock-step.
GrampyJim is offline   Reply With Quote
