Diesel Forum - TheDieselStop.com - View Single Post - Lack of towing power
Old 08-23-2009, 11:03 PM   #12 (permalink)
kraftchick
Update: went to AutoZone today and had them check the codes via the OBD II....nothing....not one code has been thrown. When I first had them hook up the reader, it wouldn't connect at all....like the OBD connector was dead. I checked the fuse box, and sure enough, that 20amp fuse was blown. Replaced it, then their reader connected.........yet, no codes at all. If oil cooler and/or EGR cooler were not functioning properly, and I had an abnormal rise in either oil temp or coolant temp.....could this cause the PCM to degrade power, yet produce no codes?
kraftchick is offline   Reply With Quote
