Diesel Forum - TheDieselStop.com - View Single Post - Where to buy hubs?
Old 08-28-2009, 03:38 AM   #2 (permalink)
klhansen
klhansen's Avatar
My Photos: (169)
I'd recommend a name brand unit. Timken would be good, or BCA/National, which I believe is the OEM manufacturer for Ford. When it comes to bearing units, you get what you pay for. What good is a 1 yr warranty if it leaves you stranded on day 366?
Hard or no-start? Check Here
