Diesel Forum - TheDieselStop.com - View Single Post - Fuel Injector Control Module (FICM)
Old 08-30-2009, 09:03 PM   #2 (permalink)
bismic
Yor FICM works hard to amplify the system voltage from 12V to 48V. If you operate with bad batteries and/or charging system, then you can ruin your FICM. It is under your 100k 5yr warranty. I believe it is even under your emissions warranty - so ZERO deductible.
Under emissions warranty, you will not be charged for labor, diagnosis, or parts for any emissions control device or system for 100k (ie no $100 deductible):
Air flow sensor
Air Fuel Feedback control System and sensors
Cold start enrichment system
Electronic engine control sensors and switches
EGR system
Exhaust manifold
Fuel Injection System
Intercooler Assembly - Engine Charger
Power Train Control Module
Turbocharger Assembly
Also covered by the two emissions warranties (Emissions defect warranty and Emissions performance warranty):
All emisssions-related bulbs, hoses, brackets, tubes, gaskets, seals, belts, connectors, non-diesel fuel lines and wiring harnesses that are used with components on the list above.
Mark
bismic is offline   Reply With Quote
