Diesel Forum - TheDieselStop.com - View Single Post - New England Meet
Old 08-30-2009, 11:23 PM   #1 (permalink)
kolo
kolo's Avatar
New England Meet
Well as promised Dan put on the beginning of a good meet, Turn out was low however, I'm sure a lot of food and beer, Yes beer had to be taken home. And when I say food , I mean a wide variety as well. The weather might have kept some of you away, If Dan does this again don't let the weather keep you away as the setting is perfect rain or shine. The park is large enough to provide multiple covered pavillions. This one even had a fire place which Dan had put to use. The setting is fairly private under the trees and bathrooms are also close by. There is ample room to spread out and play ball or whatever in the fiels as well. quite a few nice trucks and custom Mods as well. Thanks for the effort Dan, hope to do it again next year, with a larger turn out this could be quite and event and well worth traveling a couple of hours for if needed.
1993 F450 Superduty 2 whl drive,7.3 IDI, E4OD auto, non Turbo, reg. cab flat bed, mostly stock I believe.
1997 F350 crew cab 4x4, PSD, open air intake, 3"down pipe,MBRP, sonnax valve in auto, gutted EBPV, 130,000 miles, 4.10 limited slip,fifth whl. hitch, now Dually with 96 Axle, International water pump w/coolant filter, 57 gals. w Bronco rear/ 24 plastic front, electric fan on tranny cooler.
kolo is offline   Reply With Quote
