Originally Posted by ssaulnier
Can the scanguage be programmed to display engine coolant tempreature, engine oil temperature and boost pressure on the 6.0 liter diesel? I want to monitor these temperatures while towing my trailer.
Thanks, Steve
I don't think you can get engine oil temp. Trans temp yes, oil temp no.
You can check on the ScanGauge site to find out what you can and cannot display.
Mike
D70 Full floating rear axle from a cutaway van
140A Alternator. 125W solar panel. Sportsmobile off-road trailer.
96,258 miles. 16.63 mpg average
From Cal to Alaska, Key West, Labrador/Newfoundland and points in between
05 F350 front axle and aluminum wheels 275/70-18 tires.
46 Gal tank - harpooned pump vent tube.
Scangauge. DieselSite Coolant Filter@72K. Fumoto valve. Amsoil dual remote oil filter setup.
176 days in the shop - not counting the 4wd conversion time - Replaced front springs, 2 injectors, Trans housing, 3rd gear, Reverse planetary assy, Turbo, Alternator, another Alternator, Turbo hose fitting, Block Heater, Door lock, Front axle seals - all under warranty. AC hose, 1 injector, Batteries not under warranty.
