Racor makes a quality unit but they are not very easy on the wallet. Perma cool also makes a water separator thats not to badly priced. Guys have also used Goldenrod water separators and they are available at Tractor Supply.
I would stick with the stock filter over the 7.3 unit as the stock one filter down to a smaller micron rating. If your on a budget you could stick a bolt in the end of the drain tube on the water separator to stop air from entering.
Stock fuel supply line is 3/8"
35GPH is about what the stock fuel system flows.
Installation of a water separator is just that simple to. Bolt it up and hook up your fuel lines
-Justin
1984 F250 6.9 C6 2WD Push Button Wellman GPs, No Soup bowl. Wix 33439 Water Separator, Carter P4594 fuel pump, Custom 3" Exhaust, NTZ Oil Bypass Filter, VDO Vision water temp gauge, ISSPRO EV Pyro
http://photobucket.com/CDX825
