Originally Posted by Pappy19
No one is saying the V-10 is THE most powerful engine out there. However, I'll say it again, the test that Truck Trend did 2 years ago on the 2008 models had all of the maker's diesel and gas rigs towing a 28' bumper tow up the same hills, down the same drag strip, both solo and towing. The only difference was that the V-10 truck had a 4.10 rear, as did the Chevy and Dodge gassers, while all of the diesels had a 3.73 rear. The Ford V-10 was faster than all of the gas engines and equal to or superior to all of the diesel engines. In fact the only time the V-10 was out-done was the 6.4 Ford diesel test up a 11% grade. Yes, the V-10 is cheaper, not only by the initial $7,000 cost but in maintenance costs as well. If you tow heavy alot, then by all means get a diesel. If you tow a boat or RV trailer once in a while, then you can't beat the V-10. If you don't hop up your diesel, you will be passed up by the new V-10's, cause I've done it. In fact, you'll have to hop up your diesel to out do a new V-10.
If you say so, I dont buy it.
2006 F250 cc/sb sct, studs egr delete, 100 shot injectors, fass fuel pump, twins, rough country 4-link 8" Lift, 38"x15.5" Dick Cepeks, 20x12 Rockstars, 4" Dual Exhaust, Ranch hand bumpers Front & Rear
2002 F350 XL RC/LB Pro Comp 6.5" Lift, 37"x13.5" SuperSwamper M16s, Stage II's, GTP38 turbo, DP Tuner, AFE intake, 5" exhaust, JW Slush Box, AIH Delete, CCV Mod, Zoodad mod, 5.6k mod, FPR Shim, ATS Flex Plate, ATS Torque Converter, AirDog FP-150, Fluidampr.
2006 Ram 2500 QC/SB Smarty, 5" straight pipe, edge, Leveling kit, 35x13.5" mickey ATZs
2006 International CXT DT466 300 hp 860 tq Diablo powerpuck, 6" straight pipe into 7" single stack
