Originally Posted by bpathfinder
Took it in this morning had it checked they pulled same code I did. They said Ford makes them reprogram the (FICM) and try it again. Same thing again, it was bad. Put new one on and it was covered under the emissions warranty, so I got lucky and did not have to pay a deductible.
fantastic! Did they volunteer the "no-deductible" or did you have to remind them?
Mark
