You will find you get no real help from Superchips. If you are running a 1705 tuner, the only thing it changes is the line pressure in the transmission. I had one of these and had similar issues that you guys are experiencing. I sent it back to them two times, always with the "we will fix it up for you" attitude. Got it back both times and nothing changed. I sold it and bought the DP-Tuner. You can feel the shift strategy change between programs and when I run my Autoenginuity on the truck you can verify the differences. Tuners are "one size fits all" they will not change parameters for you on a case by case basis. If you want to see a difference put in a custom tuned chip from one of the popular chip builders on this site. I ended up towing in stock for a whole summer because I would not use that programmer again.
Ken
Powerstroke Acronyms
TSB Information
