Diesel Forum - TheDieselStop.com - View Single Post - air intakes...which one
Old 09-13-2009, 10:23 AM   #23 (permalink)
Strokin' 6.0
Strokin' 6.0's Avatar
The only reason you could halfway justify going with S&B would be that you buy it and you're done, whereas with the stock unit, you have to replace it and drop anywhere from $57 (cheapest I've found) to $85 (stealership cost) each time. Of course, how long does a stock filter last? Well, my truck is an '04 and I still have the original filter on it, going on 98,000 miles. I guess if you do a lot of off-roading, replacing the OEM setup would be a PITA to your wallet, but the facts are facts....OEM is made by Donaldson, one of the leading filter manufacturers out there, and their unit flows just as good as S&B.
My opinion, stick with OEM, even though the S&B looks cooler! I think that's what bugs a lot of folks, is that the OEM setup looks restrictive, even though it's not.
Fred
2004 F-350 CC DRW LB FX4 4x4
Oxford White/Arizona Beige
King Ranch
Herrin Hauler bed
4.10 Trac-Lok
Reman'd 6.0L @43,956 miles
Reman'd Turbo @54,814 miles
Strokin' 6.0 is offline   Reply With Quote
