Diesel Forum - TheDieselStop.com - View Single Post - Report: 2011 Ford Super Duty Will Debut at Texas State Fair
Old 09-14-2009, 11:50 PM   #5 (permalink)
B-rad
The bedplate design is far better and stronger than normal rod caps, but I know what you are saying about the leaking. i have seen many 6.0's leaking from the bed plate, hopefully with the reverse manifold design this will help the issue. The bed plate is a very strong design for its purpose, but gives a place for leaks to form.
1993 Bronco, 351, 5 speed conversion, 6 inch lift 35's. In process of one ton swap.
1996 F-150, I6, 2wd, regular cab, shortbed, reliable as hell.
2003 Harley Davidson sportster, 1200, 100th year edition
2007 Yamaha YFZ450, to go where the Bronco cant
2002 Ford F-350 7.3, CC, LB, auto everything, 315/75/16 with level kit only, Torador Red, BIG RED
B-rad is offline   Reply With Quote
