Diesel Forum - TheDieselStop.com - View Single Post - 1998 E-350 Powerstroke 7.3L Diesel Coolant change
Old 09-16-2009, 06:38 PM   #2 (permalink)
blageurt
blageurt's Avatar
I would buy some coolant test strips from Napa or elsewhere and test it to see where you are. Then , I would add 50/50 Prestone green coolant , or whatever you like as long as it's rated for our trucks and add 1 bottle of the Ford coolant additive , retest and do what you have to do to keep it in spec . . .
95 E350 PSD HD Cargo , BB shim , E4OD , B&M aluminium Trans pan , Twin HD coolers , Cat sleeps with the fishes , 3:55 D70FF, Michelin LTX " E " , DP flashed 60 Tow , 140 V idm , Autometer Triple Pillar Guage pod , New Injector O-rings /IPR /lift pump / filterbowl @ 235K , Timbrens SES kit , replaced lift pump /ICP/ IDM @ 256 K
1977 F350 Dually Dump , 460 , 429 POLICE heads , 4:56 D70FF, Edelbrock Intake , Holley 850 dbl pmper ,MSD IGN , Custom HiPo C-6 Trans , Dual Exhausts , Bridgestone "E" Tires
1983 KZ1000R , Yoshimura Stage I
1982 KZ1000 , 1045 Wiseco , Turbo ready
1990 KX500
blageurt is offline   Reply With Quote
