I am installing leather seats in a fleet grade XL F250 crew cab 4X4 with a 5.4 Lt. The ones I am using came out of a wrecked 08 Diesel F350 crew cab.
I need some help with the wire coding in the harness which runs under the seats. I assume the black/purple is the ground, the light green (?) and the yellow/red the power. I am left with a yellow/grey and red/grey out of the leather seats wiring harness which seem not to match anything in the truck I am upgrade, The yellow/red also did not match, but I ran it to the same location as it was in the wrecked truck (large plug under the passenger side fuse box kick panel). I have connected the green wire and the black/purple wire from the leather seat harness to the the same code coloired wire in the wiring harness cross cab under seat harness.
I am getting no power and seem to have a short someplace as the battery is draining. I suspect it is the yellow/red that is shorting. What I am planning on doing is running it directly to power with a fused link. I suspect however that I have to figure out the yellow/grey and red/grey wires before anything is going to work.
So, who can help and what should I do?
Bruce
