Diesel Forum - TheDieselStop.com - View Single Post - Water / Meth injection
Old 09-21-2009, 11:59 AM   #2 (permalink)
thuglike
thuglike's Avatar
Cooling Mist is the best kit I've seen by far. I picked mine up from KT Performance. Running straight water won't hurt anything as long as it's set up right. I set my 2 stage to come on at 15 and 30lbs of boost. It's prob. the safest injection mod you can do. Problems start when you add meth to the formula. 30% meth is safe, you can run that all year long without fear of freezing or blowing up your motor. After you get over 50% meth/ water ratio....that's when you need to be careful. Meth is a fuel and by adding it to your engine yo add timing. You'll need to adjust your tunes for it. You are totally safe runnin' straight water or up to 40% meth. Go off of boost to engauge your stage(s) and your motor will live a long happy life.
'00 F-250 X-cab 4x4: Powered by DI PERFORMANCE
Best run to Date: Spring Fling-706/1400- ALL FUEL/ 12.21 @ 110.45 Diesel Nationals (all fuel)
thuglike is offline   Reply With Quote
