Originally Posted by frankdt
I'll try turning off everything else, like the AC.
If the key is in the correct position none of that will run, and the steering wheel will be unlocked.
Any idea who's a good contact with Ford to discuss this with?
Good luck with that. When I worked there I tried to get manglement interested in running towing tests and developing ways to tow four down. None of the manglement in transmission engineering Rv'd so they had no interest.
I do know that the TorqShift trans does not like spinning without the engine running. We failed several transmissions on dynamometers when the dyno had a problem and reset. The trans would spin from the dyno and the one way clutch would get trashed from lack of lube flow.
