Diesel Forum - TheDieselStop.com - View Single Post - Question about flat towing an 08 F250 PSD
Old 09-21-2009, 09:11 PM   #12 (permalink)
frankdt
I believe the whine is the injectors (or whatever drives the injectors) and it's only when you shift from P to neutral. Once in neutral no matter what position the key is in this continues.
Looks like the solution is to put the key in the first position (accessory) and use the manual shift override. Move it to neutral and no whine!! steering unlocked, trans in neutral and nothing is powered up! Problem solved.
Not many F-250s being pulled around behind a motorhome but roadmaster makes all the brackets and adapters. I did pull it around town on Sunday and pulled fine... Don't even know it's there! 18 ton vs 4 ton = truck? What truck?
2008 F-250 Lariat 4x4 PSD 6.4L
2008 MB E320 Bluetec Diesel 3.0L
2005 Freightliner Columbia NRC MH 12L
frankdt is offline   Reply With Quote
