Diesel Forum - TheDieselStop.com - View Single Post - Questions about WMO in 7.3 IDI, airplane engine oil...
Old 09-22-2009, 03:14 AM   #4 (permalink)
skibarefoot
I assume your airplane oil is from recips and not jets. If recips should be OK unless you having some exoctic oil if from jets don't use it. Jet oil will eat your seals.
2002 EX 4x2 Amsoil front to back with Amsoil oil bypass filtration, Cyclone Power fan, HX oil line, Dieselsite prepump and tank mods, local high performance transmission, MagHytec pans,MBRP 4" exhaust, AFE Stage II, BD EBV exhaust brake, Bright Box, Diesel Turbo Life Saver, Dieselsite 6pos. chip, Trans, EGT, Pyro and water temp gauges, Dieselsite tranny cooler, Dieselsite 203dg t-stat, Dieselsite AIH plug, rerout ccv, Coolant filter, Firestone Ride Rites, hellwig rear sway bar, Garrett BB turbo. Dieselsite hpop filter, Auto Enginuity program. Dieselsite Adrenaline hpop.
skibarefoot is offline   Reply With Quote
