Diesel Forum - TheDieselStop.com - View Single Post - Question about flat towing an 08 F250 PSD
Old 09-22-2009, 10:07 PM   #13 (permalink)
95DRW4x4
95DRW4x4's Avatar
Check a diagram of your transfercase (T/C) to see if it has a small pump and pick-up tube attached to the rear output shaft. Or call a transmission shop that rebuilds T/Cs and ask them.
From what I understand you want the trans in gear so it doesn't turn even when the T/C is in nuetral. I know on my ZF, in my Ranger, the lower part of the gears will not turn if the engine is off and clutch in gear. So if the trans output shaft, into T/C, spins the upper part of my trans gears can spin unlubricated. So when I tow my Ranger I put the trans in 5th gear and T/C in nuetral.
95 F350, 7.3 PSD, CC, ZF5 speed, 4x4, Dually, Autometer EGT, Boost and Engine Temp Gauges, DP and 4 inch exhaust, Tymar Intake, CPR Fuel System, Adrenaline HPOP
85 Ranger, 302, ZF5 speed, Klune-V, Dana 20, Explorer front and rear diffs, 35 inch TSLs, ARBs, Superwinch
95DRW4x4 is offline   Reply With Quote
