Diesel Forum - TheDieselStop.com - View Single Post - Question about flat towing an 08 F250 PSD
Old 09-22-2009, 10:18 PM   #14 (permalink)
md18
You don't want to tow with the transmission in neutral, there could be enough drag from the fluid to turn the transmission output shaft which has no lubrication without the engine running. You should however, run a charge wire from the 7-way connevtor to your trucks batteries, this will keep your batteries from draining if there are any parasitic loads with the key in that position.
Wouldn't it be a little more "economical" to tow the E320 though? lol
2002 F350 CC SB Lariat 7.3 4x4 3.73 LS
Torredor Red, Viper 5701
md18 is offline   Reply With Quote
