Here you go:
Originally Posted by 88beast
anyone know where i can read up on calculating compression?
im looking to run 19 or 20-1 not much lower but enough and id like to run around 20 psi boost then if possible so i need to figure all that out
Calculating Compression Ratio
I understand not being able to drive out here if it's in a rock crawer or mudder...
1997 Jayco 323RKS fifth wheel w/2 slides, Air Lift 5000 bags
Train Horns: Pictures here
PM please not visitor message
