I am looking at increasing my exhaust to 4 inches and adding the DP-tuner as the only mods to my X. I should be able to get by with the similar tunes you have. It is just a simple plug and play system correct? Do you ever tow more the 10,000#? If so how does the 80 tow work? Did you notice smoother trany shifting once you started using the tuner. A little off the subject but I noticed you have a hellwig sway bar, is it only in the back or front too? How do you like it. Thanks for the feedback.
01 Excursion, 4 x 4 Limited, 265/75/16 Firestone Transforce HT maintain 72 psi front- 70 psi in rear, Superchip, 3.73 rear end, Airbags front and back (10-15 psi) 275,000 miles.
01 F-350 dually, 4 x 4 Lariat, Hypertech chip, AFE air intake, 4 inch MBR Exhaust, rear air bags (25-50 psi) 110,000 miles.
