I installed the magnaflow TUNER KIT exh. with has a 3 1/2" head pipe and 4" for the rest. Best for engines running just tuners or chips. The tuner does just plug into computer, but you must pull computer out ( behind emerg. brake pedal ) and clean contact before plugging in.Great Instuctions come with tuner. The most I tow is 7500# max with boat fully loaded with gear. They offer 60 tow for 10K # which would be safer I'm sure. The hellwig ( BIG DIFFERANCE ) in the rear,the stk.front one is fine. Shifting is more precise
