Diesel Forum - TheDieselStop.com - View Single Post - SVO-Bio mix ?
Thread: SVO-Bio mix ?
Old 09-26-2009, 06:36 PM   #2 (permalink)
airfooter
airfooter's Avatar
I know people who had better success blending VO with bio-d than diesel (less separation). Best thing to do is put a sample of your blend in a clear bottle and observe for separation. If anything falls out of solution, I wouldn't use it. Still, 25% would be max and I would only use that on longer trips - a 5 mile commute to work would be a worst case scenario.
Choose wisely. Or PLEASE post pics of the carnage!!!
2001 F-350, DRW, 4x4, XLT Crew Cab, flat bed, 7.3, 6 spd, Dipricol Optix gauges on pillar - EGT, Boost, Fuel Press., HPO Press. - No Muffler, AIH delete, SB Con OFE, AC code injctrs, GTP 38R. Vegistroke-inspired WVO system w/150,000 trouble-free miles! BTS tunes, 203 t-stat w/billet housing, Evans coolant, coolant filter, boost relief valve, Dieselsite IC boots, Hella headlight harness, '07 grill/lites and big, bad front bumper!
2000 Excursion 4x4 Limited - BTS trans and tunes, AIS, Frybrid/V3 SVO conversion with over 100k VO miles so far!
That's 250k miles on SVO between them!
airfooter is online now   Reply With Quote
