Originally Posted by hucklejack
I appreciate the information and it helps. I really don't tow much so if I decide to go with a brake pad and rotor combo such as woodnthings8 is using and I am not towing am I more likley to see the wheels lock up or more noise? I am not sure if I feel the investment is worth it if I am not towing heavy loads, I am a little on the fence.
Halk's don't have a lot of noise reports on this forum, probably less then I've seen with the PFs. You could go with the rotors if they give you more of a comfortable feeling about the brakes.
With a 2000, I'm not sure if you have four wheel ABS or RABS. Having the wheels lock is not a problem with 4WABS, neither with RABS with some practice. But the 4WABS needs a little more concern to the braking balance, and therefore choices between the friction materials front to rear dependign on use of the vehicle.
Do you feel you have tire skid issues?
