I'm thinking maybe a marginal PCM power relay, or possibly a fuse that's loose in it's socket.
Also, when the CPS was changed, did you look at the connections? Corroded wiring connections might cause that.
99.5 F250 PSD Supercab LB 4x4, ZF-6 w/SB Con OFE, 3.73LS, Boost & pyro gauges, Swamps S175/146 injectors, DP 80 HP Econo PCM (classic version  ), AIS, coolant filter w/"hokum" bracket, regulated return, heated mirror mod, lighted cupholder, Marinco heater plug-in.
Hard or no-start? Check Here
