Diesel Forum - TheDieselStop.com - View Single Post - Install Readylift SST 3.5" w/ question
Old 09-30-2009, 05:51 PM   #9 (permalink)
rod.10853
rod.10853's Avatar
Originally Posted by JuggyGales View Post
bump
does anyone have a solution for too short abs lines? What do others do when the lines won't sit flush on radius arms?
I would have to think that kits would come with some sort of solution.
The rubbing is really making me mad.
Couldn't you just make a bracket of some sort
that you could drill into the radius arm and them attach the
line to to hold it in place. Look at BDS install instructions,
or Fabtech instructions. You can get either from their
websites ... they use some simple brackets to raise the
mount point of the lines. It seems to me it wouldn't be to hard
to make some, or maybe you could just buy the ones that
Fabtech or BDS use? But, you're right ... Readylift needs to
address that! They should send you some brackets.
Rodney
08 F250 CC LWB 4x4 PSD, 6 SPD-Manual, 3.73 LS
2.5" Leveling Kit / 2" Superlift Add-a-Leaf
18" MT Classic II Wheels / 35" Toyo MT tires
SnugTop Truck Cap/Shell
Xtreme Liner
rod.10853 is offline   Reply With Quote
