Originally Posted by TXF-250
Thank you so much for the reply!
Injector #7 was indeed one of the ones replaced. Do you have a process that i can go by to ohm out each of the injectors? Do you do this with the motor off and basically put a volt meter in between the male and female side of the connector on top of the valve cover?
Whenever checking resistance with an ohmmeter, ALWAYS denergize the circuit. If you tried it with the engine running, you'd smoke your meter and possibly kill yourself.
The injector circuits run in excess of 100V.
To check your injector solenoids, disconnect the harness connected to the outside of the valve cover gasket. You'll see 9 pins on the gasket itself arranged like this:
G-G-I-I-C-I-I-G-G
G = glow plug
I = Injector return
C = Injector common feed
Put your meter on C and each of the I pins in turn. What you're doing is measuring the resistance of the valve cover, the UVC harness and the injector solenoid.
99.5 F250 PSD Supercab LB 4x4, ZF-6 w/SB Con OFE, 3.73LS, Boost & pyro gauges, Swamps S175/146 injectors, DP 80 HP Econo PCM (classic version
), AIS,
coolant filter w/"hokum" bracket, regulated return,
heated mirror mod, lighted cupholder, Marinco heater plug-in.
Hard or no-start? Check Here
