Originally Posted by jmpratt
My CGWR is 23,000, so if 16,400 is my max gooseneck, then I guess the truck weighs around 6,600.
Most likely that 6,600 weight figure is for a base truck (no weight adding options) with the lightest engine and tranny available, with 150 lb driver. You need to weigh your truck to see what the figures are.
Your limiting factor will be GAWR and GVWR most likely. With a tag trailer you can pull more because the tongue weight should be less than the pin weight of a gooseneck or fiver of the same weight. The figures from the towing guide are based on numbers pulled from vehicles that give the highest rating, not real world weights.
THANK YOU to all the heroes in our military and all the heroes at home who wait for their safe return. I am humbled by and grateful for your service and sacrifice.
LINK TO LIST OF THE FALLEN
'95 F250 ext cab long bed, PSD, 5 speed, 2 wheel drive, 3.55 gears, 286,000 miles, Edge Evolution CTS
(LINK TO MY REVIEW), LUK clutch, homemade
REAR BUMPER, open element
AIR FILTER, 36" ARE contractor cap. With tools, full of fuel and me on board (300 lbs) steer 3620, drive 3860 total 7480.
