Depends on how cold the weather gets. In FL, no problem. In Alaska, I wouldn't. I don't like bio because the mileage drops. I see significant drop after B40 and don't doubt there is some drop at lower percentages. So unless it is cheaper than D2, I don't buy it if I had a choice. Some will tell you it smells like french fries but unless you are trying to "off yourself" with exhaust fumes and want a nice last breath, I fail to see the point. Some will say the engine sounds quieter. So what?
01 Excursion 7.3L Powerstroke. Gauges with AIH Delete, AIS, CCV Mod, 4' MBRP, BTS Trans, 6.0L Trans Cooler and Intercooler, DP-Tuner F5 chip, ITP In Tank Mod and Boost Annihilator, Diesel Innovation's Regulated Fuel kit, BTS Big Oil system, GTP38R Turbo with 1.15 A/R housing and BPD Stage II AC injectors. Bilstein Shocks with U code front and A code Rear.
