Originally Posted by 88beast
thanks for the info typefour
im going to reuse all the original parts i can that are within spec
i still need to calculate the comp ratio so once i do then ill know the pistons i need
according to the file I have saved the 93/94 7.3 IDI has 21.5:1 compression stock.
1997 Jayco 323RKS fifth wheel w/2 slides, Air Lift 5000 bags
Train Horns: Pictures here
PM please not visitor message
