Diesel Forum - TheDieselStop.com - View Single Post - stout motor build
Old 10-01-2009, 11:29 PM   #27 (permalink)
chuckster57
chuckster57's Avatar
Originally Posted by 88beast View Post
stand will be fine im giong to pull the heads first and still support it with a 2x4
anyone know the tranny bolt size? i need to pick some up to hold it
i know thats the compresion chuckster thanks though
i meant the new compression ratio because i want to run twin turbos on it like the new superduty on the same pipe
i think na it will need to be around 19.5-1 then at first turbo (always spinning) 20-1 then 21-1 or so with the second kicked in
Yeah I realized what you meant after I posted and thought about it. I did give you the formula for figuring it out right? I am getting antsy to see some pics here...
1997 Jayco 323RKS fifth wheel w/2 slides, Air Lift 5000 bags
Train Horns: Pictures here
PM please not visitor message
chuckster57 is online now   Reply With Quote
