Diesel Forum - TheDieselStop.com - View Single Post - 6.0 vs vt365
Thread: 6.0 vs vt365
Old 10-02-2009, 12:42 PM   #12 (permalink)
dikkstarr
dikkstarr's Avatar
Originally Posted by Ljutic SS View Post
Not all of them are junk, there's a early 2003 out in the driveway with 120,000 on it that never left me stranded. Matter of fact it never stayed over night at a dealer either. Never had the EGR valve out, the only thing I ever replaced on it was a TFT sensor in the trans.
Good the early 03s were overbuilt compared to all the rest, my buddy has one, his has 29000 tho...but
I once thought as you did.
Youre lucky so far, but like I said its a matter of time until it breaks. All the typical things that plauge these trucks are gonna happen to yours all at once, or one after another like mine did costing me thousands of dollars. All my probs started at 78000, so I thought my truck was pretty cool until then, now 10000 bux later, and the problem I have now that no one can fix, I want out. These motors are money pits, and ford has a monopoly on fixing them, which they dont. If ford fixed them the way they should, they would be slitting their own throats. They know a certain part is bad or doesnt work, but they put the same crap bad part back in instead of fixing it or the problem that makes it break.
Have you read on here that the last flash "inductive" might be killing our ficm moudules prematurely? A flash ford created thats ruining parts on our truck. Expensive parts. And who do you think is gonna pay for a new ficm when the flash burns them out? Sounds like job security, rippoff
The 6.0l motor has surpassed Hot Chicks as the greatest Money reducing Agent known to Mankind.
2004 F-250 Lariat late build 4X4 CC/LB auto,fully loaded with sunroof, power slider and backup sensors , White with 12" ICON lift, 6 superduty valved bilsteins, flip steering, 38" MTZs on 20x12 chrome Fuel Hostage wheels, stock gears, superlift truspeed, fumoto, high idle mod, large case high amp alternator, floating traction bars, airraid intake with elbow, 4" turbo back, studded, powerslots with hawk pads, billet grill, 55 watt HIDs 6000k heads and fogs, clear corners, 7" Eclipse AVN6620BT NAV w/ back up camera, massive JL stereo 300/4 and 500/1, 2 12s behind back seat, amp research steps, sirius, '08 diff cover, redhead steering box,, coolant filter kit, hush panels and door seal mod, quad pod with boost, EGT, water temp, and fuel pressure gauges
dikkstarr is offline   Reply With Quote
