Diesel Forum - TheDieselStop.com - View Single Post - IDM Code
Thread: IDM Code
Old 10-02-2009, 02:57 PM   #12 (permalink)
klhansen
klhansen's Avatar
My Photos: (169)
You're doing it right, but your meter probalby isn't the best one to use. If yours only has the two resistance ranges, it's probably straddling the range you need, which is about 0-10 ohms.
You can get a digital multimeter for less than $30 from Sears.
Craftsman Multimeter
Or a professional quality Fluke meter for about $150.
Hard or no-start? Check Here
