Diesel Forum - TheDieselStop.com - View Single Post - 99 E450 - Bad rear axle - What years will fit?
Old 10-03-2009, 04:35 PM   #2 (permalink)
carringb
carringb's Avatar
How in the world did you bend that axle?!?!
An E350 axle is not rated as high (7800 pounds) and is also 5" narrower, so it may not work with an E450 body. It will bolt up however.
I believe you have disc brakes, and I'm pretty sure the E450 came out with disc from the get-go. So any E450 axle up to 2007 would fit. '08s have a different brake setup.
What exactly is bent on the axle? Are you sure just that component can't be replace? Bending the axle tubes seems pretty much impossible.
2000 E350 DRW XLT extended wagon (yes! it's a dually!)
17" Ultra Goliath rims
Banks Powerpack, Diablo Predator
Buckstop front bumper, Reunel rear w/ 20,000# reciever
250,000+
carringb is offline   Reply With Quote
