Diesel Forum - TheDieselStop.com - View Single Post - 99 E450 - Bad rear axle - What years will fit?
Old 10-03-2009, 08:18 PM   #3 (permalink)
bradxj83
I'll have to take some pictures. Before I owned this thing, it had been in a wreck. The wreck sheared the rivets that held the front and rear shackle mounts on the drivers side, causing the axle to go backwards. There is a pretty good sized dent where the pumpkin got into the gas tank. Anyway, the reason why I am pretty sure that the axle is bent is because I have drive it maybe 1,000 miles, and it has worn 2 rear tires down to slicks. The passenger side outer tire did this, and the drivers side inner tire. I am not 100% sure that the axle is bent, but I don't know what else would do that much tire damage in that short amount of time.
Any thoughts?
Thanks for your help
1999 E450 Cutaway -7.3 auto - Makeshift cab back - 12' flat bed - 4.10 gears - 225/75/16 tires - All stock
Looking into gauges, DP tuner, water injection
Pic of rig here http://i135.photobucket.com/albums/q...IMG_2440-1.jpg
bradxj83 is offline   Reply With Quote
