Originally Posted by klhansen
You got it.
To do that, you'll need to disconnect the other end and put your meter on each end of each wire in the harness. You'll have to match wire colors with pins on each end. That's called a continuity test to see if that particular wire is intact from connector to connector.
To check for shorts between other wires is a bit more involved as there are lots of combinations. Again, with both ends disconnected, check with one meter probe on the pin you want to test, and the other probe on all the rest of the pins in sequence. While you have the meter in place (hopefully reading infinite ohms) wiggle the harness along it's entire length and watch for the meter to go to zero ohms. That indicates that the insulation between the two wires has chafed and the conductors are making contact. - But I wouldn't try that test unless you've got some indication that it's occuring, as it's fairly unlikely.
The other test is to check for short to ground. Meter probe on wire being tested, other meter probe on a ground, and again wiggle the harness bundle.
Alright well to dive into this a bit deeper...
Will I still be testing resistence (meaning do i keep the meter on the same setting I was using to ohm out the injectors)?
Also, you said to disconnect each end that goes into the valve cover in order to check the wiring harness...the problem i see with this is that theres a lot more in the bundle than just VC wires. Do I leave the rest of it hooked up?
Lastly, when you talk about checking all of the "combinations," are you saying to put one end on the harness that goes to injector 7 (for arguments sake) and then put the other end on all of the other in the harness for injectors 2,4,6, and 8?
Thanks again for all of your help!
Jourdan
2011 F250 King Ranch FX4, 6.7L with all the options
SOLD: 2002 F250 Lariat 4x4, 7.3L
DIY Intake, Zoodad, 4 inch exhaust turbo to tip, DP Tuner F5 (no start, stock, high idle, 60hp tow, 80hp econo, 120 hp race), Isspro Gauges: egt, boost, tranny (thank you girlfriend!:hail), Dieselsite Coolant Filter, AIH Delete, HPX Line, in-tank & pre-pump mods, FPR shimmed to 70 psi, Hawk Brake Pads and Powerslot Rotors, Dieselsite WW, Rhino Bedliner, 285/75 Goodyear Wrangler Silent Armors, Trailer Tow Mirrors, Bilstein Shocks, 203* T-Stat, Dieselsite Billet T-Stat Housing, Door Seal Mod, Fumoto Oil Drain Valve, Passport 9500i hardwired in w/ smartcord, A toolbox full of goodies and a few other things here and there:sly
