Diesel Forum - TheDieselStop.com - View Single Post - Detroit 60 - Aux Shutdown Help Needed!!
Old 10-05-2009, 04:04 PM   #1 (permalink)
ST3000
I need some expert technical help please guys. I really hope you can help.
I have used a Detroit Diesel Series 60 for a custom build.
I need an auxillary shutdown to protect certain bits of machinery in the event of a fault or emergency stop.
The DDEC V Vehicle Interface Harness diagram shows cable no V-41 as being 'Aux Shutdown 1'.
When I switch this cable to ground the engine stops as expected, but has trouble re-starting once the cable is cleared. Not everytime, but more often than not.
If it won't start after several attempts I find that killing the power to the EEC and restarting it 'clears' the problem.
What am I doing wrong? Is there some kind of reset I need to use?
I hope you can help, thanks in advance.
Steve.
ST3000 is offline   Reply With Quote
