I'm not Canadian but do like Canadian beer and love "Corner Gas"....does that count? ;-) The oil does not show on their website but it is at the local stores as well as motorcraft and fram oil filters. Both the fram and motorcraft versions are from the same manufacturer so either is fine (fram is usually a little cheaper). They also have a 15qt drain pan. The drain valve is an internet item. Here is a link to their main website -
FUMOTO ENGINEERING. Lastly, you should have gotten the winter grill cover from the dealer. If you have not make sure you do get one. I would imagine it is a must have in your nape of the world. If you are not near a walmart maybe you can call the website and make a special order. Unfortunately, oil is heavy so shipping tends to be expensive. Enjoy the new truck.
