Diesel Forum - TheDieselStop.com - View Single Post - exhaust brake???
Old 10-05-2009, 04:49 PM   #4 (permalink)
skibarefoot
I have the electronic exhaust brake from BD. I only use it when towing. I don't like it on when not towing because the truck doesn't decelerate smoothly. If all you want is to save your rotors then ski[ the exhaust brake and wait until the brakes wear out. Then when you change out the rotors switch to good pads and rotors. I use Hawk heavy duty pads and NAPA slotted rotors with great results.
2002 EX 4x2 Amsoil front to back with Amsoil oil bypass filtration, Cyclone Power fan, HX oil line, Dieselsite prepump and tank mods, local high performance transmission, MagHytec pans,MBRP 4" exhaust, AFE Stage II, BD EBV exhaust brake, Bright Box, Diesel Turbo Life Saver, Dieselsite 6pos. chip, Trans, EGT, Pyro and water temp gauges, Dieselsite tranny cooler, Dieselsite 203dg t-stat, Dieselsite AIH plug, rerout ccv, Coolant filter, Firestone Ride Rites, hellwig rear sway bar, Garrett BB turbo. Dieselsite hpop filter, Auto Enginuity program. Dieselsite Adrenaline hpop.
skibarefoot is offline   Reply With Quote
