Diesel Forum - TheDieselStop.com - View Single Post - Broke the heater plug-in off the harness. Darn.
Old 10-09-2009, 02:39 PM   #8 (permalink)
JustCris
Originally Posted by klhansen View Post
I second and third (can I do that? ) the Marinco Mod. I've had one on my truck for many years. Had the cord break off flush with the rear of the original plug, and put on a heavy duty plug temporarily, then installed the Marinco recessed plug. Never looked back.
It'll be a grounded (3-wire) cord. DEFINITELY connect all three wires to the plug. If the hot wire happens to chafe it'll energize the whole truck unless the ground is connected, which will then trip the breaker, protecting you.
If you were to touch the truck with a hot wire shorted to the chassis, it'd surely curl your hair, and might even kill you. It wouldn't be good to be holding on to your truck doing a dance and not being able to let go.
Here's the diagram for plugs and receptacles: Plug and Receptacle Configurations
It'll be a NEMA 5-15P configuration.
Yep, just walked outside & checked, it's 3 wires, one was tucked back inside the factory electrical tape harness cover stuff. Definately going to mull over the marincomod. Now I just need to figure out which truck wires correspond to the diagram's for wiring up the plug. As it's voltage I'll remember to lick my fingers before touching anything.
Formerly CrisinColorado, Owner of a dark shadow grey '02 PSD F350. CrewCab Dually 6-spd. Most options. Diablo 70+ H.P Chip. Magnaflow S.S. Turbo Back 4" System.. A.Meter 3gauge stuffed with Autometer's. Speed Grill & chrome lady adornment on the flaps. Use it to pull 29 ft. Forest River Toy Hauler 5er. It holds a 1965 U-2 Mallock Ford powered Vintage Road Racer (900#'s of fun!). Also own a '78 Volvo 242GT that had a Ford heart transplant. '90 5.0 & matching 5speed. Rollbar, 6pt belts...ready to race
JustCris is offline   Reply With Quote
