So I took my block heater plug off of the filter base and rang out the wires on my plug. Look at the pictures so you can see how it should be wired. You should be able to use a meter to do the same, just might need a helper to reach both.
[IMG]  /IMG]
Ken
Powerstroke Acronyms
TSB Information
