Diesel Forum - TheDieselStop.com - View Single Post - Dieselsite Coolant filter installed - 6.0 Van
Old 10-10-2009, 10:06 AM   #2 (permalink)
ridintall
ridintall's Avatar
I've attached some pics of my install. I mounted the coolant filter in an empty space behind the front Aluminess bumper. I chose this space over the frame rail as it's more protected from road debris. Also, I did not include a picture of the line splice into the reservoir bottle hose as it's the same as the pickup trucks.
As I stated above, the hardest part of this project was cutting into the heater hose, only because of an aluminum sleeve inside the hose that prevented me from cutting straight through it and the lack of space to work in. At no time did I need to disconnect or unbolt anything to make the splice. I was able to reuse some of the coolant that leaked out during the install that I was able to catch in a pan underneath, but still needed to top it off with some. So far so good, no leaks. I plan on making an emergency field repair kit with barbed fittings and extra hose just in case.
Oogs
Dieselsite Coolant filter installed - 6.0 Van-t-fitting.jpg   Dieselsite Coolant filter installed - 6.0 Van-hose_to_filter.jpg   Dieselsite Coolant filter installed - 6.0 Van-filter_lines.jpg   Dieselsite Coolant filter installed - 6.0 Van-filter.jpg
2004 6.0 E350 Quigley 4x4 w/ Sportsmobile Conversion.
285/75R16 BFG AT/KO. 3.73 Gears.
Dieselsite Coolant Filter.
Aluminess Front/Rear Bumpers.
125W Solar Panel.
Sportsmobile Trailer on 285/75R16 BFG AT/KO tires w/ dual deep cycle marine batteries, water pump, 10 gal water storage, air compressor, storage box & 15W Solar Panel.
Wiring Harness Recall - 15K miles
EGR Valve replaced @ 30K miles
Oil & EGR Coolers replaced @ 62K miles
Tank delamination - Reconditioned by Gas Tank Renu @ 62K miles
Vacuum Pump replaced 69K
SnowMan Mod / Door Seal Mod
ridintall is offline   Reply With Quote
