hello again...
in the process of ohming out the wiring harness right now.
How do I figure out which wire on the harness is ground?
UPDATE: I finally matched up the pin on the passenger side vc to the one on the main harness mounted on the drivers side. Got a reading 0.7 ohms...moved wires around and jiggled everything...still stayed at 0.7. I guess this means that the wiring harness is ok? Now, do i have to go from the Driver's side main harness to the pcm, and then from the pcm to the idm? Or is it from the harness straight to the IDM?
Jourdan
2011 F250 King Ranch FX4, 6.7L with all the options
SOLD: 2002 F250 Lariat 4x4, 7.3L
DIY Intake, Zoodad, 4 inch exhaust turbo to tip, DP Tuner F5 (no start, stock, high idle, 60hp tow, 80hp econo, 120 hp race), Isspro Gauges: egt, boost, tranny (thank you girlfriend!:hail), Dieselsite Coolant Filter, AIH Delete, HPX Line, in-tank & pre-pump mods, FPR shimmed to 70 psi, Hawk Brake Pads and Powerslot Rotors, Dieselsite WW, Rhino Bedliner, 285/75 Goodyear Wrangler Silent Armors, Trailer Tow Mirrors, Bilstein Shocks, 203* T-Stat, Dieselsite Billet T-Stat Housing, Door Seal Mod, Fumoto Oil Drain Valve, Passport 9500i hardwired in w/ smartcord, A toolbox full of goodies and a few other things here and there:sly
