Originally Posted by TXF-250
Alright then, so i guess that means perform the same test i performed on the injector circuits, but now on the harness from the IDM to the valve cover. Should i expect to see about the same reading?
Yes
If it passes the test, does this then mean the IDM is bad?
That's a possibility. If you have a buddy with a 7.3L, you could try your IDM in his truck and see if the same symptoms appear. That'd probably be easier than checking the harness from the 42-pin to the IDM. The IDM connector would be a PITA to get at.
99.5 F250 PSD Supercab LB 4x4, ZF-6 w/SB Con OFE, 3.73LS, Boost & pyro gauges, Swamps S175/146 injectors, DP 80 HP Econo PCM (classic version
), AIS,
coolant filter w/"hokum" bracket, regulated return,
heated mirror mod, lighted cupholder, Marinco heater plug-in.
Hard or no-start? Check Here
